InfluxDB schema design recommendations
Use the following guidelines to design your schema for simpler and more performant queries.
InfluxDB data structure
The InfluxDB Cloud Dedicated data model organizes time series data into databases and tables. A database can contain multiple tables. Tables contain multiple tags and fields.
  • Database: A named location where time series data is stored. In InfluxDB Cloud Dedicated, database is synonymous with bucket in InfluxDB Cloud Serverless and InfluxDB TSM implementations.
    • Table: A logical grouping for time series data. In InfluxDB Cloud Dedicated, table is synonymous with measurement in InfluxDB Cloud Serverless and InfluxDB TSM implementations. All points in a given table should have the same tags. A table contains multiple tags and fields.
      • Tags: Key-value pairs that store metadata string values for each point–for example, a value that identifies or differentiates the data source or context–for example, host, location, station, etc. Tag values may be null.
      • Fields: Key-value pairs that store data for each point–for example, temperature, pressure, stock price, etc. Field values may be null, but at least one field value is not null on any given row.
      • Timestamp: Timestamp associated with the data. When stored on disk and queried, all data is ordered by time. In InfluxDB, a timestamp is a nanosecond-scale Unix timestamp in UTC. A timestamp is never null.
What happened to buckets and measurements?
If coming from InfluxDB Cloud Serverless or InfluxDB powered by the TSM storage engine, you’re likely familiar with the concepts bucket and measurement. Bucket in TSM or InfluxDB Cloud Serverless is synonymous with database in InfluxDB Cloud Dedicated. Measurement in TSM or InfluxDB Cloud Serverless is synonymous with table in InfluxDB Cloud Dedicated.
Primary keys
In time series data, the primary key for a row of data is typically a combination of timestamp and other attributes that uniquely identify each data point. In InfluxDB, the primary key for a row is the combination of the point’s timestamp and tag set - the collection of tag keys and tag values on the point. A row’s primary key tag set does not include tags with null values.
Overwriting points with the same primary key (timestamp and tag set) is not reliable for maintaining a last-value view. For recommended patterns, see Duplicate points in the line protocol reference.
Tags versus fields
When designing your schema for InfluxDB, a common question is, “what should be a tag and what should be a field?” The following guidelines should help answer that question as you design your schema.
  • Use tags to store metadata, or identifying information, about the source or context of the data.
  • Use fields to store measured values.
  • Tag values can only be strings.
  • Field values can be any of the following data types:
    • Integer
    • Unsigned integer
    • Float
    • String
    • Boolean
InfluxDB Cloud Dedicated indexes tag keys, field keys, and other metadata to optimize performance. It doesn’t index tag values or field values.
The InfluxDB 3 storage engine supports infinite tag value and series cardinality. Unlike InfluxDB backed by the TSM storage engine, tag value cardinality doesn’t affect the overall performance of your database.
Schema restrictions
Do not use duplicate names for tags and fields
Use unique names for tags and fields within the same table. InfluxDB Cloud Dedicated stores tags and fields as unique columns in a table that represents the table on disk. If you attempt to write a table that contains tags or fields with the same name, the write fails due to a column conflict.
Maximum number of columns per table
A table has a maximum number of columns. Each row must include a time column. As a result, a table can have the following:
  • a time column
  • field and tag columns up to the configured maximum
If you attempt to write to a table and exceed the column limit, then the write request fails and InfluxDB returns an error.
InfluxData identified the default maximum as the safe limit for maintaining system performance and stability. Exceeding this threshold can result in wide schemas, which can negatively impact performance and resource use, depending on your queries, the shape of your schema, and data types in the schema.
Design for performance
How you structure your schema within a table can affect resource use and the performance of queries against that table.
The following guidelines help to optimize query performance:
Avoid wide schemas
A wide schema refers to a schema with a large number of columns (tags and fields).
Wide schemas can lead to the following issues:
  • Increased resource usage for persisting and compacting data during ingestion.
  • Reduced sorting performance due to complex primary keys with too many tags.
  • Reduced query performance when selecting too many columns.
To prevent wide schema issues, limit the number of tags and fields stored in a table. If you need to store more than the maximum number of columns, consider segmenting your fields into separate tables.
Avoid too many tags
In InfluxDB, the primary key for a row is the combination of the point’s timestamp and tag set - the collection of tag keys and tag values on the point. A point that contains more tags has a more complex primary key, which could impact sorting performance if you sort using all parts of the key.
Avoid sparse schemas
A sparse schema is one where, for many rows, columns contain null values.
These generally stem from the following:
Sparse schemas require the InfluxDB query engine to evaluate many null columns, adding unnecessary overhead to storing and querying data.
For an example of a sparse schema, view the non-homogenous schema example below.
Writing individual fields with different timestamps
Reporting fields at different times with different timestamps creates distinct rows that contain null values–for example:
You report fieldA with tagset, and then report field B with the same tagset, but with a different timestamp. The result is two rows: one row has a null value for field A and the other has a null value for field B.
In contrast, if you report fields at different times while using the same tagset and timestamp, the existing row is updated. This requires slightly more resources at ingestion time, but then gets resolved at persistence time or compaction time and avoids a sparse schema.
Table schemas should be homogenous
Data stored within a table should be “homogenous,” meaning each row should have the same tag and field keys. All rows stored in a table share the same columns, but if a point doesn’t include a value for a column, the column value is null. A table full of null values has a “sparse” schema.
View example of a sparse, non-homogenous schema
Use the best data type for your data
When writing data to a field, use the most appropriate data type for your data–write integers as integers, decimals as floats, and booleans as booleans. A query against a field that stores integers outperforms a query against string data; querying over many long string values can negatively affect performance.
Design for query simplicity
Naming conventions for tables, tag keys, and field keys can simplify or complicate the process of writing queries for your data. The following guidelines help to ensure writing queries for your data is as simple as possible.
Keep table names, tags, and fields simple
Use one tag or one field for each data attribute. If your source data contains multiple data attributes in a single parameter, split each attribute into its own tag or field.
Table names, tag keys, and field keys should be simple and accurately describe what each contains. Keep names free of data. The most common cause of a complex naming convention is when you try to “embed” data attributes into a table name, tag key, or field key.
When each key and value represents one attribute (not multiple concatenated attributes) of your data, you’ll reduce the need for regular expressions in your queries. Without regular expressions, your queries will be easier to write and more performant.
For example, consider the following line protocol that embeds multiple attributes (location, model, and ID) into a sensor tag value:
home,sensor=loc-kitchen.model-A612.id-1726ZA temp=72.1
home,sensor=loc-bath.model-A612.id-2635YB temp=71.8
View written data
To query data from the sensor with ID 1726ZA, you have to use either SQL pattern matching or regular expressions to evaluate the sensor tag:
SELECT * FROM home WHERE sensor LIKE '%id-1726ZA%'
SELECT * FROM home WHERE sensor =~ /id-1726ZA/
SQL pattern matching and regular expressions both complicate the query and are less performant than simple equality expressions.
The better approach would be to write each sensor attribute as a separate tag:
home,location=kitchen,sensor_model=A612,sensor_id=1726ZA temp=72.1
home,location=bath,sensor_model=A612,sensor_id=2635YB temp=71.8
View written data
To query data from the sensor with ID 1726ZA using this schema, you can use a simple equality expression:
SELECT * FROM home WHERE sensor_id = '1726ZA'
This query is easier to write and is more performant than using pattern matching or regular expressions.
Avoid keywords and special characters
To simplify query writing, avoid using reserved keywords or special characters in table names, tag keys, and field keys.
When using SQL or InfluxQL to query tables, tags, and fields with special characters or keywords, you have to wrap these keys in double quotes.
SELECT
  "example-field", "tag@1-23"
FROM
  "example-table"
WHERE
  "tag@1-23" = 'ABC'
See the Blog Post
For more information:
docker pull influxdb:2
