title: Telegraf Enterprise license enforcement
description: How Telegraf Controller enforces scale limits and Enterprise feature gating based on your license status, including expiration phases, grace period behavior, and response headers.
url: https://docs.influxdata.com/telegraf/controller/telegraf-enterprise/license-enforcement/
estimated_tokens: 2230
publisher: InfluxData
canonical: https://docs.influxdata.com/telegraf/controller/telegraf-enterprise/license-enforcement/
date: '2026-06-24T05:47:49-07:00'
lastmod: '2026-06-24T05:47:49-07:00'
* Telegraf Enterprise
Telegraf Controller enforces two things based on your license status: how
many resources you can create (scale limits) and which features are available.
This page describes both kinds of enforcement and how license expiration affects
them.
#### Telegraf Enterprise
Unlock higher configuration and agent limits, enhanced security features, and official support for Telegraf and Telegraf Controller.
[ Upgrade to Enterprise](/telegraf/enterprise/)
* [Scale limits](#scale-limits)
* [Enterprise feature gating](#enterprise-feature-gating)
* [License expiration lifecycle](#license-expiration-lifecycle)
* [Response headers](#response-headers)
* [Reference: JWT claims](#reference-jwt-claims)
## Scale limits
Telegraf Controller enforces a maximum number of configurations and a
maximum number of reporting agents per instance.
|    Resource    |Free tier|                    Telegraf Enterprise                    |
| Configurations |   20    |Defined by `ent_max_configs` in your license (per contract)|
|Reporting agents|   100   |Defined by `ent_max_agents` in your license (per contract) |
The free-tier values are hardcoded into the Telegraf Controller binary and
cannot be overridden.
### What happens when a limit is reached
* “Create” endpoints (such as `POST /api/configs`) return`402 Payment Required` with an error body identifying the resource, the
  current count, and the limit:
    "error": "entitlement_limit_reached",
    "resource": "configs",
    "current": 20,
    "limit": 20,
    "message": "configs limit reached (20/20). Upgrade to Telegraf Enterprise for higher limits."
* The corresponding create button in the Telegraf Controller UI is disabled
  and shows a tooltip explaining the limit.
* The response includes an `X-Entitlement-Warning` header (see[Response headers](#response-headers)).
A warning banner appears in the UI when usage reaches 80% of a limit so
operators have advance notice before requests start being rejected.
## Enterprise feature gating
A valid Telegraf Enterprise license unlocks the following features:
* [Audit logging](/telegraf/controller/audit-logs/)
* [LDAP authentication](/telegraf/controller/authentication/ldap/)
* [OIDC authentication](/telegraf/controller/authentication/oidc/)
API endpoints that require an enterprise feature return `403 Forbidden` when
called on a free-tier instance:
```json
  "error": "feature_not_licensed",
  "feature": "audit_logging",
  "message": "audit_logging requires a Telegraf Enterprise license."
#### Identity provider environment variables on a free-tier instance
If `AUTH_LDAP_*` or `AUTH_OIDC_*` environment variables are set on a
free-tier instance, Telegraf Controller starts normally and logs a
warning that the feature requires a license. The feature stays inactive
until a license is applied and Telegraf Controller is restarted so the
variables are re-read.
## License expiration lifecycle
A license moves through four stages relative to its `license_exp` (contractual
expiration) date:
|Time relative to `license_exp`|    Status     |Scale limits|Enterprise features|        UI behavior        |
|   More than 30 days before   |    `valid`    |  Licensed  |      Enabled      |         No banner         |
|       1–30 days before       |  `expiring`   |  Licensed  |      Enabled      |Info banner with countdown |
|       0–14 days after        |`expired_grace`|  Licensed  |      Enabled      |Error banner with countdown|
|    15 or more days after     |   `expired`   | Free tier  |     Disabled      |       Error banner        |
The grace period is fixed at 14 days and is not configurable. Expiration
status is re-evaluated hourly, so a status change takes effect within one
hour without requiring a restart. To switch back to a valid status sooner,
apply a renewed license through the UI. Uploads take effect immediately.
## Response headers
Telegraf Controller adds the following headers to HTTP responses when the
corresponding condition is true. Monitor these headers in deployment health
checks to detect license-related issues before they affect users.
|        Header         |                  When it appears                   |                                          Value                                           |
| `X-License-Expiring`  |           License expires within 30 days           |                                 ISO 8601 expiration date                                 |
|  `X-License-Expired`  |   License is past expiration but still in grace    |                                          `true`                                          |
|`X-Entitlement-Warning`|One or more entitlements at 90% or more of the limit|Comma-separated `resource current/limit` pairs, for example `configs 18/20; agents 95/100`|
## Reference: JWT claims
The following table describes the claims contained in a Telegraf Enterprise
license JWT. Claims are informational. You don’t author license files
yourself, but understanding what each claim controls helps when reading
license details, scripting around licensing, or interpreting validation
errors.
|      Claim      |      Type      |                                           Description                                            |
|      `id`       | string (UUID)  |          Unique license identifier. Use this value when contacting InfluxData support.           |
|      `iss`      |     string     |                 Issuer. Always `InfluxData Licensing Server` for valid licenses.                 |
|      `iat`      | Unix timestamp |                                   When the license was issued.                                   |
|      `exp`      | Unix timestamp |                                      JWT token expiration.                                       |
|  `license_exp`  | Unix timestamp |Contractual license expiration. Drives the [enforcement lifecycle](#license-expiration-lifecycle).|
|`ent_max_configs`|positive integer|                               Maximum configurations entitlement.                                |
|`ent_max_agents` |positive integer|                              Maximum reporting agents entitlement.                               |
#### Related
* [Troubleshoot Telegraf Enterprise licensing](/telegraf/controller/telegraf-enterprise/troubleshoot/)
* [Authentication](/telegraf/controller/authentication/)
* [Authentication and authorization](/telegraf/controller/reference/authentication-authorization/)
| Resource | Free tier | Telegraf Enterprise |
| Configurations | 20 | Defined by  ent_max_configs  in your license (per contract) |
| Reporting agents | 100 | Defined by  ent_max_agents  in your license (per contract) |
| Time relative to  license_exp | Status | Scale limits | Enterprise features | UI behavior |
| More than 30 days before | valid | Licensed | Enabled | No banner |
| 1–30 days before | expiring | Licensed | Enabled | Info banner with countdown |
| 0–14 days after | expired_grace | Licensed | Enabled | Error banner with countdown |
| 15 or more days after | expired | Free tier | Disabled | Error banner |
| X-License-Expiring | License expires within 30 days | ISO 8601 expiration date |
| X-License-Expired | License is past expiration but still in grace | true |
| X-Entitlement-Warning | One or more entitlements at 90% or more of the limit | Comma-separated  resource current/limit  pairs, for example  configs 18/20; agents 95/100 |
| id | string (UUID) | Unique license identifier. Use this value when contacting InfluxData support. |
| iss | string | Issuer. Always  InfluxData Licensing Server  for valid licenses. |
| iat | Unix timestamp | When the license was issued. |
| exp | Unix timestamp | JWT token expiration. |
| license_exp | Unix timestamp | Contractual license expiration. Drives the  enforcement lifecycle . |
| ent_max_configs | positive integer | Maximum configurations entitlement. |
| ent_max_agents | positive integer | Maximum reporting agents entitlement. |
