title: Apply a Telegraf Enterprise license
description: Apply a Telegraf Enterprise license to Telegraf Controller using the LICENSE_FILE_PATH environment variable at startup or by uploading the license through the UI.
url: https://docs.influxdata.com/telegraf/controller/telegraf-enterprise/apply-license/
estimated_tokens: 1892
publisher: InfluxData
canonical: https://docs.influxdata.com/telegraf/controller/telegraf-enterprise/apply-license/
date: '2026-10-20T15:51:00-06:00'
lastmod: '2026-10-20T15:51:00-06:00'
* Telegraf Enterprise
Apply a Telegraf Enterprise license to Telegraf Controller either at startup
through an environment variable or at runtime through the user interface.
#### Telegraf Enterprise
Unlock higher configuration and agent limits, high availability, enhanced security features, and official support for Telegraf and Telegraf Controller.
[ Upgrade to Enterprise](/telegraf/enterprise/)
* [Prerequisites](#prerequisites)
* [About the license](#about-the-license)
* [Apply a license at startup](#apply-a-license-at-startup)
* [Apply a license through the user interface](#apply-a-license-through-the-user-interface)
* [Verify the license is active](#verify-the-license-is-active)
* [What happens if validation fails](#what-happens-if-validation-fails)
## Prerequisites
* A Telegraf Enterprise license issued by InfluxData and provided to you as a
  “license key.” You can optionally store your license in a file with a `.jwt`or `.txt` file extension.
  If you have already purchased Telegraf Enterprise, but have not recieved your
  license, [contact InfluxData support](https://support.influxdata.com).
* For the UI method: the **Owner** role on the Telegraf Controller instance.
## About the license
Telegraf Enterprise licenses are signed JSON Web Tokens (JWTs). The license
is text string that you can optionally store in a file with a `.jwt`or `.txt` file extension. Take care not to edit the actual license key.
Any change invalidates the cryptographic signature.
Telegraf Controller validates licenses in both connected and
air-gapped environments.
## Apply a license at startup
Save your license key to a `.jwt` or `.txt` file and use the `LICENSE_FILE_PATH`environment variable to apply a license when Telegraf Controller starts. This
method is recommended for automated and infrastructure-as-code deployments.
1. **Place the license file on the Telegraf Controller host.**
   Copy the license file to a path the Telegraf Controller process can read,
   for example `/etc/telegraf-controller/license.jwt`.
2. **Set the `LICENSE_FILE_PATH` environment variable.**
   [systemd](#systemd)[Shell](#shell)[Windows (Powershell)](#windows-powershell)[Docker](#docker)
   Add an `Environment=` line to your systemd unit file (typically`/etc/systemd/system/telegraf-controller.service`):
   [Service]
   Environment=LICENSE_FILE_PATH=/etc/telegraf-controller/license.jwt
   Then reload systemd and restart the service:
   sudo systemctl daemon-reload
   sudo systemctl restart telegraf-controller
   Export the variable in your shell before starting Telegraf Controller:
   export LICENSE_FILE_PATH=/etc/telegraf-controller/license.jwt
   telegraf_controller --no-interactive
   Set the environment variable in PowerShell before starting
   $env:LICENSE_FILE_PATH="C:\ProgramData\telegraf-controller\license.jwt"
   ./telegraf_controller.exe --no-interactive
   Pass the environment variable and mount the license file when starting the
   container:
   docker run \
     --env LICENSE_FILE_PATH=/etc/telegraf-controller/license.jwt \
     --volume HOST_LICENSE_FILE:/etc/telegraf-controller/license.jwt:ro \
     influxdata/telegraf-controller:1.2.2
   Replace `HOST_LICENSE_FILE`with the path to the license file on the host.
   Make sure the license file on the host is readable by the container user
   (for example, `chmod 644`). Include your standard container options, such as
   EULA acceptance, published ports, and the data volume.
   See [Run Telegraf Controller in Docker](/telegraf/controller/install/docker/).
3. **Start (or restart) Telegraf Controller.**
   On startup, Telegraf Controller reads the file, validates the license, and
   stores it in the database. Successful loads appear in the startup logs with
   the license ID.
> [!Note]
> #### `LICENSE_FILE_PATH` is read only when the database has no license
> If the Telegraf Controller database already contains a license,`LICENSE_FILE_PATH` is ignored on subsequent restarts. To replace a license
> applied this way, either [upload a new license through the UI](#apply-a-license-through-the-user-interface)or [remove the existing license](/telegraf/controller/telegraf-enterprise/manage-license/#remove-a-license)first.
If the file is missing, unreadable, or contains an invalid license,
Telegraf Controller starts in free-tier mode and logs the validation error.
See [Troubleshoot licensing](/telegraf/controller/telegraf-enterprise/troubleshoot/)for the error catalog.
## Apply a license through the user interface
Use the Telegraf Controller UI to apply or replace a license at runtime
without restarting the application. This method requires the **Owner** role.
1. Sign in to Telegraf Controller as a user with the **Owner** role.
2. Navigate to **Settings \> Enterprise**.
   <img src="/img/telegraf/controller-licensing-upload-form.png" alt="Upload your Telegraf Enterprise license to Telegraf Controller" width="913">
3. Provide the license in one of two ways:
   * **Drag and drop** the `.jwt` (or `.txt`) license file into the drop zone.
   * **Paste** the license key (JWT) string into the textarea.
4. Click **Upload license**.
Telegraf Controller validates the license immediately. On success, the page
refreshes to show the license ID, expiration date, and entitlements. No
restart is required. Enterprise features and the new scale limits take
effect for all in-flight and subsequent requests.
If validation fails, an error message describes the reason. The previously
active license (if any) remains in effect. Telegraf Controller never downgrades
from a valid license because of a failed upload.
## Verify the license is active
**In the UI**, navigate to **Settings \> Enterprise** to view the current
license details: license ID, the date the license was loaded, the expiration
date, the maximum configurations entitlement, and the maximum reporting agents
entitlement.
**From the API**, any authenticated user can call `GET /api/license/entitlements`to see the current entitlements and usage. This is the recommended endpoint
for status checks in scripts and monitoring dashboards because it doesn’t
require the Owner role.
```bash
curl -H "Authorization: Bearer YOUR_TC_API_TOKEN" \
  https://telegraf_controller.example.com/api/license/entitlements
Replace `YOUR_TC_API_TOKEN`with your Telegraf Controller API token.
Example response when a license is active:
```json
  "status": "valid",
  "licenseId": "Xxxx0oXx-Xx0o-00Xx-oXxX-xX0oXx0oXx0o",
  "expiresAt": "2026-12-31T00:00:00Z",
  "enterpriseEnabled": true,
  "entitlements": {
    "maxConfigs": 100000,
    "maxAgents": 18000
  "usage": {
    "configs": 47,
    "agents": 183
When no license is applied, `status` is `"unlicensed"`, `enterpriseEnabled` is`false`, and the entitlements show the free-tier limits.
## What happens if validation fails
Telegraf Controller rejects malformed, unsigned, expired (beyond the grace
period), or otherwise invalid licenses. See[Troubleshoot licensing](/telegraf/controller/telegraf-enterprise/troubleshoot/) for the
full catalog of validation errors and how to resolve them.
#### Related
* [View and update a Telegraf Enterprise license](/telegraf/controller/telegraf-enterprise/manage-license/)
* [Troubleshoot Telegraf Enterprise licensing](/telegraf/controller/telegraf-enterprise/troubleshoot/)
* [Telegraf Controller configuration options](/telegraf/controller/reference/config-options/)
