title: Configure automatic advisory checks
description: 'Control how Telegraf Controller retrieves InfluxData security advisory files: change the check interval, use an internal mirror, disable automatic checks for air-gapped deployments, run a check on demand, and read the feed status.'
url: https://docs.influxdata.com/telegraf/controller/security-advisories/configure-checks/
estimated_tokens: 3132
publisher: InfluxData
canonical: https://docs.influxdata.com/telegraf/controller/security-advisories/configure-checks/
date: '2026-10-20T11:45:34-06:00'
lastmod: '2026-10-20T11:45:34-06:00'
* Telegraf Enterprise
By default, Telegraf Controller checks for new InfluxData security advisories
automatically.
Use the options on this page to tune the schedule, route checks through an
internal mirror, turn automatic checks off for air-gapped deployments, and
trigger a check on demand.
#### Available with Telegraf Enterprise
Security advisories are available with Telegraf Enterprise. If you are interested in learning more about Telegraf Enterprise,[contact us](https://www.influxdata.com/products/telegraf-enterprise/).
[ Upgrade to Enterprise](https://www.influxdata.com/products/telegraf-enterprise/)
* [Prerequisites](#prerequisites)
* [How automatic checks work](#how-automatic-checks-work)
* [Change the check interval](#change-the-check-interval)
* [Use an internal feed mirror](#use-an-internal-feed-mirror)
* [Disable automatic checks](#disable-automatic-checks)
* [Check for advisories on demand](#check-for-advisories-on-demand)
* [View feed status](#view-feed-status)
## Prerequisites
* A valid [Telegraf Enterprise license](/telegraf/enterprise/) applied to
  your Telegraf Controller instance.
* Permission to modify the Telegraf Controller startup environment (for
  example, the systemd unit file or environment variables), to change any of the
  advisory options.
* The **Owner** or **Administrator** role, to run a check on demand from the
  UI or API.
> [!Important]
> #### Advisory options are read at startup only
> Telegraf Controller reads the `ADVISORY_*` environment variables when it
> starts. Changes take effect after a restart. These options have no
> command-line flags and no runtime settings.
> See [Security advisories options](/telegraf/controller/reference/config-options/#security-advisories).
## How automatic checks work
Telegraf Controller retrieves two advisory files, one per product:
|      Product      |                             Default feed URL                              |
|     Telegraf      |     `https://dl.influxdata.com/security-advisories/v1/telegraf.json`      |
|Telegraf Controller|`https://dl.influxdata.com/security-advisories/v1/telegraf-controller.json`|
Each check follows the same sequence for each file:
1. Download the advisory file over HTTPS.
   The request includes the `ETag` from the last successful download, so an
   unchanged file returns `304 Not Modified` and nothing else happens.
2. Download the detached signature from the same URL with `.asc` appended.
3. Verify the signature against the InfluxData public key built into
   Telegraf Controller.
   If verification fails, the file is discarded.
4. Apply the file if its timestamp is newer than the file already applied,
   then re-evaluate every agent’s exposure.
The schedule and failure handling work as follows:
* The first check runs within 30 seconds of startup.
  Later checks run every 6 hours by default.
  See [Change the check interval](#change-the-check-interval).
* If a check fails (for example, the feed is unreachable or the signature
  doesn’t verify), Telegraf Controller retries after 15 minutes, up to four
  times, and then returns to the regular interval.
  Failures are recorded in the [feed status](#view-feed-status) and never
  interrupt other operations.
* Each download times out after 15 seconds, follows at most three redirects,
  and is limited to 10 MB for the advisory file and 8 KB for the signature.
* A failure to retrieve the Telegraf Controller advisory file is recorded in
  that feed’s status but doesn’t affect the Telegraf advisory file.
In a [high-availability cluster](/telegraf/controller/admin/high-availability/),
only the leader runs scheduled checks.
The applied advisory file is stored in the shared database, so every node
shows the same advisories.
Checks on demand and manual imports work from any node.
Automatic checks require outbound HTTPS access to `dl.influxdata.com`, or to
your mirror.
See [Outbound connections](/telegraf/controller/admin/networking/#outbound-connections).
## Change the check interval
Set `ADVISORY_CHECK_INTERVAL_MINUTES` to the number of minutes between checks,
from `1` to `10080` (7 days).
Values above the maximum are capped at the maximum.
Values below `1`, and values that aren’t numbers, fall back to the default of`360` (6 hours).
```sh
# Check once per day
ADVISORY_CHECK_INTERVAL_MINUTES=1440
## Use an internal feed mirror
If Telegraf Controller can’t reach `dl.influxdata.com` directly but can reach
an internal web server, mirror the advisory files and point
Telegraf Controller at the mirror.
1. On a machine with Internet access, download the advisory file and its
   signature for each product, and copy them to a web server that
   Telegraf Controller can reach over HTTPS.
   Keep the signature next to the advisory file with the `.asc` suffix.
   Telegraf Controller always requests the signature from the feed URL with`.asc` appended.
   curl -fsSLO https://dl.influxdata.com/security-advisories/v1/telegraf.json
   curl -fsSLO https://dl.influxdata.com/security-advisories/v1/telegraf.json.asc
   curl -fsSLO https://dl.influxdata.com/security-advisories/v1/telegraf-controller.json
   curl -fsSLO https://dl.influxdata.com/security-advisories/v1/telegraf-controller.json.asc
2. Set the feed URLs in the Telegraf Controller startup environment and
   restart Telegraf Controller:
   ADVISORY_FEED_URL=https://mirror.example.com/advisories/telegraf.json
   ADVISORY_CONTROLLER_FEED_URL=https://mirror.example.com/advisories/telegraf-controller.json
3. Refresh the mirror on a schedule (for example, with a cron job) so
   Telegraf Controller picks up new advisories at its next check.
Keep the following in mind:
* Mirror URLs must start with `https://`.
  Telegraf Controller refuses to download advisory files over plain HTTP.
* The mirror must serve the files unchanged.
  Telegraf Controller verifies the InfluxData signature, so a modified file
  is rejected.
  You don’t need to re-sign anything.
* If the mirror serves an advisory file older than the one
  Telegraf Controller already applied (for example, after a newer file was
  imported manually), the check logs a warning and reports the feed as
  unchanged.
  Refresh the mirror to resume updates.
* Setting a feed URL to an empty string doesn’t disable that feed.
  Telegraf Controller uses the default URL instead.
  To stop retrieving advisories, [disable automatic checks](#disable-automatic-checks).
## Disable automatic checks
For air-gapped deployments, or any environment where Telegraf Controller
shouldn’t make outbound requests, set `ADVISORY_AUTO_CHECK` to `false` and
restart Telegraf Controller.
```sh
ADVISORY_AUTO_CHECK=false
With automatic checks disabled:
* No scheduled checks run, and **Source** in the[feed status](#view-feed-status) shows **automatic checks off**.
* The **Check for advisories** button remains available on the **Security**page. Clicking it runs a one-time check against the configured feed URL,
  which fails if the URL is unreachable.
* Advisories still reach Telegraf Controller through[manual import](/telegraf/controller/security-advisories/import/).
Any other value, including an unset variable, leaves automatic checks
enabled.
## Check for advisories on demand
Users with write permission for security advisories can trigger an immediate
check without waiting for the next scheduled run, for example after InfluxData
announces a new advisory or after you refresh a mirror.
**From the UI**, go to **Security** and click **Check for advisories**.
A notification reports **Advisories have been updated** when a newer file was
applied, or **No new advisories found** when the applied file is already
current.
**From the API**, send a `POST` request to`/api/security-advisories/feed/check` with a token that has write permission
for security advisories:
```sh
curl --request POST \
  --header "Authorization: Bearer $TOKEN" \
  https://telegraf_controller.example.com/api/security-advisories/feed/check
The response describes the outcome for the Telegraf advisory file:
```json
  "outcome": "updated",
  "wouldApply": true,
  "reason": null,
  "product": "telegraf",
  "feedTimestamp": "2026-10-14T18:00:00.000Z",
  "advisoryCount": 3,
  "source": "automatic",
  "matchedAgents": 12,
  "exposureUnknown": 2
`outcome` is `updated` when a newer file was applied, or `unchanged` when the
applied file is already current.`matchedAgents` and `exposureUnknown` report the fleet exposure after the
check.
A failed check returns one of the following errors:
|Status|             `error`             |                                                             Cause                                                             |
|`400` |`advisory_feed_invalid_signature`|                                The signature doesn’t verify against the InfluxData public key.                                |
|`400` |    `advisory_feed_malformed`    |            The downloaded file isn’t a valid advisory file, is for a different product, or exceeds the size limit.            |
|`409` |  `advisory_check_in_progress`   |                                   Another check is already running. Wait for it to finish.                                    |
|`502` |   `advisory_feed_unreachable`   |The feed couldn’t be downloaded: a network error, a timeout, a non-HTTPS URL, too many redirects, or an unexpected HTTP status.|
## View feed status
On the **Security** page, expand **Feed status**() in the overview card.
Each advisory feed shows:
* **Feed**: the product, **Telegraf** or **Telegraf Controller**.
* **Last checked**: how long ago the last check ran and its result
  (**feed updated**, **feed unchanged**, or **check failed**).
  When a check failed, the error message appears below the result.
* **Last updated**: when the currently applied advisory file was applied, in
  UTC.
* **Source**: whether the applied file came from an **Automatic** check or
  was **Imported** manually, plus **automatic checks off** when automatic
  checks are disabled.
From the API, `GET /api/security-advisories/overview` returns the same
information in the `feeds` array:
```json
  "feeds": [
      "appliedAt": "2026-10-15T02:11:08.000Z",
      "advisoryCount": 3,
      "lastCheckedAt": "2026-10-20T14:11:08.000Z",
      "lastCheckOutcome": "unchanged",
      "lastCheckError": null,
      "autoCheckEnabled": true,
      "feedUrlConfigured": true
      "product": "telegraf_controller",
      "feedTimestamp": null,
      "source": null,
      "appliedAt": null,
      "advisoryCount": 0,
      "lastCheckedAt": "2026-10-20T14:11:09.000Z",
`lastCheckOutcome` is `updated`, `unchanged`, or `failed`.
When it is `failed`, `lastCheckError` holds the error message.
#### Related
* [Telegraf Controller configuration options](/telegraf/controller/reference/config-options/)
* [Networking and ports](/telegraf/controller/admin/networking/)
* [High availability](/telegraf/controller/admin/high-availability/)
* [Import an advisory file](/telegraf/controller/security-advisories/import/)
| Telegraf | https://dl.influxdata.com/security-advisories/v1/telegraf.json |
| Telegraf Controller | https://dl.influxdata.com/security-advisories/v1/telegraf-controller.json |
| Status | error | Cause |
| 400 | advisory_feed_invalid_signature | The signature doesn’t verify against the InfluxData public key. |
| 400 | advisory_feed_malformed | The downloaded file isn’t a valid advisory file, is for a different product, or exceeds the size limit. |
| 409 | advisory_check_in_progress | Another check is already running. Wait for it to finish. |
| 502 | advisory_feed_unreachable | The feed couldn’t be downloaded: a network error, a timeout, a non-HTTPS URL, too many redirects, or an unexpected HTTP status. |
