title: Enable and configure audit logging
description: Enable audit logging in Telegraf Controller at startup, configure the retention period, and optionally forward audit events to syslog, a webhook, or a file.
url: https://docs.influxdata.com/telegraf/controller/audit-logs/enable-configure/
estimated_tokens: 1841
publisher: InfluxData
canonical: https://docs.influxdata.com/telegraf/controller/audit-logs/enable-configure/
date: '2026-07-01T07:10:10-07:00'
lastmod: '2026-07-01T07:10:10-07:00'
* Telegraf Enterprise
Enable audit logging in Telegraf Controller at startup, change the
retention period as needed, and optionally forward events to external
destinations for long-term storage or SIEM integration.
#### Available with Telegraf Enterprise
Audit logging is only available with Telegraf Enterprise. If you are interested in learning more about Telegraf Enterprise,[contact us](https://www.influxdata.com/products/telegraf-enterprise/).
[ Upgrade to Enterprise](https://www.influxdata.com/products/telegraf-enterprise/)
* [Prerequisites](#prerequisites)
* [Enable audit logging](#enable-audit-logging)
* [Configure retention](#configure-retention)
* [Forward audit events](#forward-audit-events)
* [Disable audit logging](#disable-audit-logging)
## Prerequisites
* A valid [Telegraf Enterprise license](/telegraf/enterprise/)applied to your Telegraf Controller instance.
* Permission to modify the Telegraf Controller startup environment (for
  example, the systemd unit file or startup environment).
* The **Owner** or **Administrator** role to change the retention period
  from the UI.
#### Audit-logging state changes only at startup
Per Telegraf Controller’s security policy, settings that change the
application’s security boundary, including whether audit logging is
enabled and where audit events are forwarded, can only be changed at startup.
Retention is the only audit setting that can be modified at runtime.
## Enable audit logging
Set `AUDIT_ENABLED` to `true` before starting Telegraf Controller.
#### systemd ####
Add `AUDIT_ENABLED=true` to your systemd unit file (typically`/etc/systemd/system/telegraf-controller.service`):
```ini
[Service]
Environment=AUDIT_ENABLED=true
Reload systemd and restart the service:
```bash
sudo systemctl daemon-reload
sudo systemctl restart telegraf-controller
Set the variable, or pass `--audit-enabled` on the command line:
```bash
export AUDIT_ENABLED=true
telegraf_controller --no-interactive
```bash
telegraf_controller --audit-enabled --no-interactive
Set the variable in PowerShell, or pass `--audit-enabled` on the command line:
```powershell
$env:AUDIT_ENABLED="true"
./telegraf_controller.exe --no-interactive
```powershell
./telegraf_controller.exe --audit-enabled --no-interactive
After Telegraf Controller starts:
* The **Settings \> Audit Logging** section displays as enabled.
* Audit entries begin appearing in the platform data directory described in[Where audit logs are stored](/telegraf/controller/audit-logs/#where-audit-logs-are-stored).
<img width="883" src="/img/telegraf/controller-settings-audit-retention.png" alt="Telegraf Controller audit log retention dropdown">
## Configure retention
Telegraf Controller keeps audit entries for 90 days (2160 hours) by default
and runs a cleanup job every 12 hours that removes entries older than the
retention threshold.
Available retention values:
| Value  | Hours |
|30 days | `720` |
|3 months|`2160` |
|6 months|`4320` |
| 1 year |`8760` |
|2 years |`17520`|
|Infinite|  `0`  |
### Change audit log retention from the Settings page
1. Sign in as an **Owner** or **Administrator**.
2. Navigate to the **Settings** page from the left navigation menu.
3. In the **Audit Logging** section, select a value from **Audit log retention**.
4. Click **Save**.
The new retention value takes effect immediately.
The next cleanup run removes any entries that fall outside the new window.
### Set the initial retention at startup
Use the `AUDIT_LOG_RETENTION` environment variable to seed the retention
period when Telegraf Controller initializes its settings on first startup.
```bash
export AUDIT_LOG_RETENTION=8760
> [!Note]
> `AUDIT_LOG_RETENTION` only sets the initial value.
> After first startup, the database is authoritative.
> To update audit log retention, use the **Settings** page.
## Forward audit events
Telegraf Controller can forward each audit event to one or more external
destinations in addition to writing it to local storage.
Forwarders are configured **at startup only** and run independently, which lets
you enable any combination of syslog, webhook, and file forwarders.
### Forward to syslog
Forward audit events to a syslog server over TCP or UDP.
```bash
export AUDIT_SYSLOG_HOST=syslog.example.com
export AUDIT_SYSLOG_PORT=514
export AUDIT_SYSLOG_PROTOCOL=tcp
|       Variable        |           Description            |Required|
|  `AUDIT_SYSLOG_HOST`  |   Syslog server hostname or IP   |  Yes   |
|  `AUDIT_SYSLOG_PORT`  |        Syslog server port        |  Yes   |
|`AUDIT_SYSLOG_PROTOCOL`|Transport protocol: `tcp` or `udp`|  Yes   |
### Forward to a webhook
Forward audit events as JSON `POST` requests to an HTTP webhook.
```bash
export AUDIT_WEBHOOK_URL=https://siem.example.com/ingest
export AUDIT_WEBHOOK_AUTH_HEADER="Bearer xxxxxxxxxxxx"
|    `AUDIT_WEBHOOK_URL`    |   Full URL the webhook receives `POST` requests at   |  Yes   |
|`AUDIT_WEBHOOK_AUTH_HEADER`|Optional value sent in the `Authorization` HTTP header|   No   |
The webhook forwarder retries each event up to three times with backoff and a
10-second request timeout.
Events that return `408`, `429`, or `5xx` responses are retried; events that
return other `4xx` responses are dropped.
Telegraf Controller honors a `Retry-After` response header when present.
### Append to a file
Append each event to a file as a single JSON object per line (`.jsonl`).
```bash
export AUDIT_FILE_PATH=/var/log/telegraf-controller/audit.jsonl
The path must be writable by the Telegraf Controller process.
Telegraf Controller does not rotate or trim this file. Pair it with a
system log rotator (such as `logrotate`) if you keep the forwarder on long
term.
## Disable audit logging
To turn audit logging off, remove `AUDIT_ENABLED` (or set it to a value
other than `true`) and restart Telegraf Controller.
The startup-only policy applies in both directions: audit logging cannot be
disabled from the UI.
Existing audit files remain on disk and continue to be readable through[`GET /api/audit-logger`](/telegraf/controller/audit-logs/view/) until they
age out of retention.
#### Related
* [Telegraf Controller configuration options](/telegraf/controller/reference/config-options/)
* [Apply a Telegraf Enterprise license](/telegraf/controller/telegraf-enterprise/apply-license/)
| Value | Hours |
| Value | Hours |
| 30 days | 720 |
| 3 months | 2160 |
| 6 months | 4320 |
| 1 year | 8760 |
| 2 years | 17520 |
| Infinite | 0 |
| Variable | Description | Required |
| AUDIT_SYSLOG_HOST | Syslog server hostname or IP | Yes |
| AUDIT_SYSLOG_PORT | Syslog server port | Yes |
| AUDIT_SYSLOG_PROTOCOL | Transport protocol:  tcp  or  udp | Yes |
| AUDIT_WEBHOOK_URL | Full URL the webhook receives  POST  requests at | Yes |
| AUDIT_WEBHOOK_AUTH_HEADER | Optional value sent in the  Authorization  HTTP header | No |
