Use Grafana with InfluxDB
This page documents an earlier version of InfluxDB OSS. InfluxDB 3 Core is the latest stable version.
Use Grafana or Grafana Cloud to visualize data from your instance.
Detect my InfluxDB version
Grafana 12.2+
The instructions below are for Grafana 12.2+ with the newInfluxDSConfigPageDesign feature flag enabled. This introduces the newest version of the InfluxDB core plugin. The updated plugin includes SQL support for InfluxDB 3-based products such as , and the interface dynamically adapts based on your product and query language selection in URL and authentication.
Required
  • The instructions below are for Grafana 12.2+ with the newInfluxDSConfigPageDesign feature flag enabled. This introduces the newest version of the InfluxDB core plugin. For information about using InfluxDB with other versions of Grafana, see the Grafana documentation.
  • To use Flux, use InfluxDB 1.8.1+ and enable Flux in your InfluxDB configuration file.
Install Grafana
  1. Start InfluxDB.
  2. Sign up for Grafana Cloud or download and install Grafana.
  3. If running Grafana locally, enable the newInfluxDSConfigPageDesign feature flag to use the latest InfluxDB data source plugin.
    Option 2: Command line
  4. Visit your Grafana Cloud user interface (UI) or, if running Grafana locally, start Grafana and visit http://localhost:3000 in your browser.
Using Grafana Cloud with a local InfluxDB instance
If you need to keep your database local, consider running Grafana locally instead of using Grafana Cloud, as this avoids the need to expose your database to the internet.
To use InfluxDB running on your private network with Grafana Cloud, you must configure a private data source for Grafana Cloud.
SQL is only supported in InfluxDB 3. For more information, see how to get started with InfluxDB 3 Core.
  2. Click Data sources.
  3. Click Add new connection.
  • URL: Your server URL–for example, https://localhost:8086
  • Product: From the dropdown, select InfluxDB OSS 1.x
  • Query Language: Select InfluxQL or Flux
Configure database settings
Configure Grafana to use InfluxQL
When you select InfluxQL as the query language, configure the following:
InfluxQL configuration for InfluxDB OSS 1.x
Click Save & Test. Grafana attempts to connect to InfluxDB and returns the result of the test.
Configure Grafana to use Flux
When you select Flux as the query language, configure the following:
  1. Ensure Flux is enabled in your InfluxDB configuration file.
  2. Configure the database settings:
    • Organization: Provide an arbitrary value (InfluxDB 1.x does not use organizations)
    • Default Bucket: Provide a default database and retention policy
    • Token: If InfluxDB authentication is enabled provide your InfluxDB username and password
Flux configuration for InfluxDB OSS 1.x
Query and visualize data
Query inspection in Grafana
To learn about query management and inspection in Grafana, see the Grafana Explore documentation.
New in InfluxDB 3.8
See the Blog Post
docker pull influxdb:2
